I have read the manual for the Rockcliff driver board and still not sure about E-Stop.
The diagram shows a NO E-stop,
The paragraph (Axis Enable / Disable) mentions a NC E-stop and removing the jumpers. Is one way better than the other?
My thinking is not using A so remove this jumper and then wire a NO e-stop as in the diagram.
Then the software (Mach3) also goes into stop mode when pressed??
Mechanical E-Stop pulled out to enable and also need to reset software E-stop to be able to restart
I was just thinking as a NC E-Stop being hard wired to enable if a wire breaks it would go into stop???? Maybe that would be better?
Would remove the enable jumpers on the board for this.
Maybe I am just confusing myself.
Any suggestions are appreciated as the E-Stop should work properly and I don't want to screw it up
