1. Send program to TNC155B
2. If necessary, edit in edit mode
3. Press the 'Run full program' 'Run ful program' you mean press button for automatic?
4. Press program number and confirm you are in correct program
5. (if necessary) press [Goto] 0 (or whatever) to make sure you start from the beginning of the program That i do
6. (if necessary) press [Mode] and select Iso-3 or 3D etc. That i do
7. (if necessary) press [BlkForm] to get the blank workpiece displayed That i do
8. Press the graphics [Start] That i do
9. While it is running, there is a * next to the line number at the top of the screen If I have in the Auto mode, showing me * at the top of the screen on the left and is considered a lines. However, the model nothing happens. When come to the end of sentences, the model did not change.
10. If there is no *, it is stopped either at the end of program, or waiting for a tool change? If it stops, just press the graphics [Start] again. As I mentioned, the model did not change. Although I came to the end of the program. |
