  #12   Ban this user!
Old 09-14-2009, 09:01 PM
jsheerin's Avatar
jsheerin jsheerin is offline
jsheerin is on a distinguished road
No - you don't move the axis with the motors. You just rotate the indicator in the spindle. The assumption is your table surface is flat and parallel to the x and y axes already and thus moving the spindle around in x and y is unnecessary. If your z axis is out, there will just be ridges or scallops in the spoilboard from surfacing it (how big depending on how far out of alignment the z axis is). The longer the arm the indicator is on (and the further away from the spindle's center line), the bigger the errors shown on the indicator. Ideally you would rotate the spindle and the indicator reading would never change as you swept a complete circle. If your z axis is not perfectly perpendicular to your table, then when you compare readings from +x and -x, there will be some difference and you can shim as appropriate. Same for y, although typically you would unbolt things and tap in the alignment in the y direction the way most router are built.
