Old 09-13-2009, 09:43 PM
pwintulich pwintulich is offline
pwintulich is on a distinguished road
Hello Christian,
There are two types of internals i have seen in the 240 model.
A photo of the inside will tell me what type it is. I can help work out the wiring and may be provide a replacement interface board if it turns out to be the best way to getting your machine running.
The documentation I have is the opperating manual for the BBC controled version. I can create circuit diagrams from the one I have. If yours is the later design I can help identify the wiring, but I am not sure I could get it running with the existing control board that is in it.
I have been distracted from working on mine, as I have been cleaning up around home after getting a milling machine into the shed its a BridgePort clone. It needs new electronics and axis motors, as they were removed before I purchased it. There is also some minor mechaninal damage I wan't to repair before I get it going again.
How were you thinking of controlloing it? By PC or BBC ?
If PC then MACH3, Turbo CNC, EMC2?
I think it is better to get it running under control of a PC because the available software is much better these days.
Regards Peter Wintulich
