  #12   Ban this user!
Old 09-12-2009, 11:51 AM
Torchhead Torchhead is offline
Torchhead is on a distinguished road
Well, your right. A MACH based system with our DTHC interface requires a University Degree to operate. First find someone that can turn on the machine, start the PC and load the "magic control program". A PhD in Computer Science is recommended (or find a 9 year old).
Here is a list of the complex set of operator steps to cut a job:
1. Load File - G-code - [Filename from list] If you need help on this please contact the PHD that started the machine for you.
2. Click "CUT PROFILES" Button (NO, NO!! LEFT Button)
3. Select the type material you are cutting (this is where your degree cuts in) If it's not on the job ticket then just guess.
4. Look at the info at the top of CUT PROFILES and confirm you have the plasma turned on and set to the correct AMPS because if you don't and it starts to cut it will STOP and HONK at you!
5. Click "OK" (advanced users only)
6. Hit "RUN" button
7. Remember not to stare at the pretty white flame
8. NEVER walk off while it's cutting! The boss will see you and replace you with the village idiot.
All of this assumes some moron upstairs that generated the cut file used the right CAM POST and it's not for the CNC router across the shop.
You can mount a false knob or two on the front of the control so the operator THINKS they are doing something to earn their princely sum but that is optional.
(Sorry, I just couldn't resist)
TOM Caudle
www.CandCNC.com
University Educated CNC Operator
