Hi
Yes think your six points sum it up nicely.
Our customers want to load a plate, press the minimum number of buttons and set the machine cutting while they do something else. I am sure this can be done on the mach3 type of smaller machines, but the industrial ones are designed to do just that, load - select - cut, with automatic setup.
Just for the record I would class Daves machine as hobby/light industrial and the attached picture as industrial. Basic operation the same, both run from a standard pc.
Mike |
