Old 09-10-2009, 09:21 AM
stevo1 stevo1 is offline
stevo1 is on a distinguished road
Ok Ash I am with you now.
Yes this is done all the time. It is the exact same concept of gathering the data points as I gave you in the previous post. This is commonly done and then the DPRNT function is used to send the data to PC/printer. Now I don’t know how to do it to the memory card because I don’t use one. I do know that it is possible. I can help you to write the program to get the dimensions of the parts into the variables on the machines but we are going to need someone else to chime in on the memory card syntax. I will also need some help with the exact code your Mits control uses.
Do you have any books on this control or anyway of finding out what the variables are for the “current machine position”? Any examples on macro programming would also be helpful.
The most logical thing to do is write 3 separate programs to find the points on a square, rectangle, and circle then put that data in the variables so that they can be written to the memory card.
The “parametric” forum here does not get a lot of traffic so if we don’t see anyone chime in on the memory card or some pointers on the mits code then I will PM a few people to see if they can help out.
Stevo
