Old 09-10-2009, 08:50 AM
taperedbearings taperedbearings is offline
taperedbearings is on a distinguished road
Lathe macro program mazak bearing Roller
I help need with creating a simple macro to turn a bearing roller simple cylinder with a hole, and tapered roller with a radius face. i have a g code program without the macros variables i need to add some loops and logic to it to use the #500 variables please help. i've wrote several for grinders just not for lathes.
here is the code i have to work with
(MSG, 69556-3.EIA 1.25" X 2.35" TAPER ROLLER K069556-3M BHB 08/26/09)
G0 G18 G20 G40 G53 G80 G96 G99 G111
G30 U0
G30 W0
G99
G111
G50 S4000 R1
M901
N10 T1010.03 G96 S660 M4 R1 M8
(MSG, WALTER DWLNL 16 4 D HOLDER- FACING UP AND LEFT)
(MSG, ROUGH TURN LEAVING .015")
G0 Z0.1 X1.7
Z0.015
G1 X-0.062 F0.02
G0 Z0.1
X1.4537
G1 Z-2.63742
X1.5
G0 Z0.1 X1.7
X1.1538
G1 Z-0.00012
G3 X1.36004 Z-0.15036 I-0.05788 K-0.15024
G1 Z-0.18059
X1.35991 Z-0.18503
X1.21031 Z-2.63742
X1.4537
G0 Z0.1 X1.7
G30 U0
G30 W0
M1
G99
G111
G50 S4000 R1
M901
N20 T0202.01 G96 S700 M4 R1 M8
(MSG, FINISH FACE AND TURN - HD1)
G0 Z0.1 X0.44625
Z0.05238
X0.42192
G1 X1.0904 Z-0.00656 F0.012
G3 X1.32991 Z-0.15378 I-0.02518 K-0.1428
G1 X1.17944 Z-2.62046
G0 Z-2.505 X1.37946
Z0.1
G30 U0
G30 W0
M1
G99
G111
G50 S4000 R1
M901
N30 T0606.01 G97 S3000 M3 R1 M8
(MSG, NINE-9 CHAMFER TOOL)
(MSG, SPOT FOR DRILL)
G0 Z0.1 X0.0
G1 Z-0.177 F0.0033
G0 Z0.1
G30 U0
G30 W0
M1
G99
G111
G50 S4000 R1
M901
N40 T1212.01 G96 S80 M3 R1 M8
(MSG, -J- (.277) HSS DRILL 2.4" MIN FLUTE LENGTH)
(MSG, DRILL THRU)
G0 Z0.0 X0.0
G1 Z-0.65 F0.003
G0 Z0.0
Z-0.6
G1 Z-0.85
G0 Z0.0
Z-0.8
G1 Z-1.05
G0 Z0.0
Z-1.0
G1 Z-1.25
G0 Z0.0
Z-1.2
G1 Z-1.45
G0 Z0.0
Z-1.4
G1 Z-1.65
G0 Z0.0
Z-1.6
G1 Z-1.85
G0 Z0.0
Z-1.8
G1 Z-2.05
G0 Z0.0
Z-2.0
G1 Z-2.25
G0 Z0.0
Z-2.2
G1 Z-2.45
G0 Z0.0
Z-2.4
G1 Z-2.49322
G0 Z0.0
G30 U0
G30 W0
M1
G99
G111
G50 S4000 R1
M901
N50 T0707.01 G96 S205 M3 R1 M8
(MSG, .625" C.E.M.)
(MSG, SPOTFACE PER PRINT)
G0 Z0.0 X0.0
G1 Z-0.037 F0.0016
G0 Z0.0
G30 U0
G30 W0
M1
G99
G111
G50 S4000 R1
M901
N60 T0303.01 G97 S1200 M3 R1 M8
(MSG, SECO CFML 100 05D W/SECO LCMF 160505-A187-MT CP500)
(SET Z TO RIGHT SIDE OF TOOL)
(MSG, BACK END RADIUS AND CUT-OFF- HD1)
G0 Z-2.355 X1.7
X1.52992
G1 X0.76071 F0.003
X1.48992
G0 Z-1.94426
X1.30695
G1 X1.19707 Z-2.25584
G3 X0.96071 Z-2.355 I-0.11818 K0.02084
G1 X-0.04
X1.48992
G0 X1.7
G30 U0
G30 W0
G28 B0
M1
M99
