Hi Stevo
Thanks for your time, patience & Support.
Well, I again need to elaborate you about my requirement -
We have parts which have a nominal tolerance & we want to inspect it on machining centre. As the geometery of the parts are round, square or rectangular shape, so it will be possible to inspect on machining centre.
As the parts are not 3D profile & also not having close tolerance ( either customer would prefer CMM machine for the same ).
So i want to do is edge find the part & than plot in a CAD software & then by deducting edge finder radius value & than conclude whether they reflect to the drawing tolerances.
WELL I WANTED TO ASK, WHETHER IS THERE ANY SUCH PARAMETRIC PROGRAM WHICH CAN CAPTURE THE MACHINE READINGS IN A FILE (than the file can be transfered to Computer through Memory card ).
Well i guess i have cleared the direction for all.
Thanks All
Ash |
