There are multiple ways of doing this, Red. If your machine can do helical interpolation, then there would be no problem.
However, a lot of CADCAM software also has a utility to create helices composed of very short line segments which approximate the helix. In this case, you only need to check if your controller is capable of doing a 3 axis linear movement.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
