We are updating out AVC-2 Torch Height Control and are looking for 2 Beta sites for testing.
This is a low cost unit with 2 volt accuracy. It is not suitable for High Definition type of cutting. Our market is the conventional plasma systems. This includes Hypertherm PowerMax, Thermal Dynamics, and ESAB Inverter type machines, or older High Frequency machines.(Max-100, Pak10, etc.
The target price is less than $1,250.00 with out lifter, and $2,500 with a single speed AC lifter.
This unit is THC only and requires an existing lifter with 120 VAC Up/Down contorls.
We would like to find someone with non Hypertherm Plasma. (We already have a Hypertherm site). High Frequency start is OK.
Also the closer to the northeast section of the US the better.
We will provide the AVC-2 unit, a voltage divider, cables and instructions to connect.
You will provide feedback on the operation and at the end of the test period you can keep the AVC-2.
A unit with IHS (initial Height Sensing) is also in the works.
Contact me directly if you are interested
alan@plasmatechnologies.com
