Old 09-04-2009, 08:30 AM
Geof Geof is online now
Have you ever hand tapped 1" NPT?
I doubt very much that a 1/2" bar through your cross hole will be strong enough for the torque needed. Also the OD of the head may be a bit small and the material about the overcut corners of the pocket too thin, these will very likely split.
