That would be about 20khz you need from the software.
Turbocnc will work it dose about 28khz on a Pentium.
Do you have a specific design you need to cut?
Do you need to change often?
Reason I ask is with enough time on your hand you can
even hand code it to make it work.
Of course if you have a large variety of parts and lots of
changes this is too tedious.
Cam Software is very expensive any medium quality
software starts at somewhere around $3000.- and up.
I would recommend you start with something simple
and learn to gcode manualy.
This will be of great value to you even after you get a
Cam program setting up Postprocessors requires some
good knowlege about your controllers requirements.
Good Luck |
