For a very small machine, I'd go with moving table, as the bearings the gantry would ride on would take up a lot of the Y axis. If it's a larger design, then moving gantry's got to be the way to go. Imagine you want a cutting area of around X=4' * Y=6'. For moving table the Y axis would have to be double the cut required (12'). If you had moving gantry and the gantry bearings were say, 12" length span, then you'd need 7' for the Y axis instead of 12'
That's how I view it.
Regards Terry..... |
