Cabinetcraft,
What quilting machine do you have, which sewing machine rides on it? As I said earlier, and I probably misread what you said in your post, as it appears that you are wanting to computerize a manual quilting machine. That is exactly what I have done. My wife has a Husqvarna Viking machine on a Grace Quilt machine frame with a 24 inch width. The table is 112 inches long. I am driving the system using two NEMA 17 1.8 degree steppers bipolar. I designed a cable system using 35 pound test polyethylene covered stainless steel fishing wire that I picked up at the local fishing store. It works very well and pulls the carriage very smoothly on the table. I am using Mach3 for the controlling software, set at 1/8 step, 800 steps, with a resolution of .05. It may be possible to get better resolution by changing the pully wheel on the stepper on the x-axis to a smaller wheel. 1/1 would be the best but you know how that goes, you use what you can get and then do the math to change it. How is the project going now?
Larry |
