Thread: Floating Z Head
Old 08-29-2009, 06:13 AM
tulsaturbo's Avatar
tulsaturbo tulsaturbo is offline
tulsaturbo is on a distinguished road
Originally Posted by lowpull View Post
Its not setup in mach , it is setup in your post processor. In sheetcam my post processor has a place for me to put my offset which is .26
This is the code it then produces for every pierce.
N0110 G28.1 Z0.12
N0120 G92 Z0.0
N0130 G00 Z0.2600
N0140 G92 Z0.0
N0150 G00 Z0.1300
N0160 M03
It makes the z go down until the switch is tripped. It sets the z axis dro to 0. It raises the z the offset number (.26 in my case). It again sets the z axis to 0. Now the top of the metal is at 0 and the the tip of the torch is at 0. It raises the z axis to the pierce height. ( I use .13 in this case) and starts cutting.
Hope this helps.
That helped out bunches. Thanks for the explanation!
So I would set up the floating Z head switch in mach3 under - config / ports and pins / input signals / Z Home, correct?
Would I need to configure the (Safe Z) as well (config / safe_Z setup) and if so whats the common setup to go with as I see that it gives 3 options to choose from?
TIA
