Here's some numbers for an ISO 30 taper based on a cone clutch calculation taken from machinery's handbook. As you can see low drawbar force looks OK for relatively high rpm's but if you have a geared head mill then you might be in trouble at low rpm. It's torque that is the potential problem not HP.
Phil
