Originally Posted by salmve Let us suppose that we use same machine and engrave same job with 100w tube and after that 60w tube. Previous test we have found out that required power is 30w. 100w tube has adjust at 30% of power and 60w tube at 50% of power. Which makes better quality? And why?
Vekku |
You could achieve the same result, providing the lens has the same spot size. Commonly the spot size is larger on 100W, so the potential resolution is lower. Depending on the application that may not be important.
Zax.
