Old 02-19-2005, 08:39 AM
fantasy2 fantasy2 is offline
fantasy2 is on a distinguished road
Originally Posted by gmfoster
Thats the one
G0 F300
The F300 doesn't do anything.
The G0 says go as fast as it can go.. You should never be able to actually do work with a G0 command it is just for moving to a new location or returning home.
G1 F300 means to move at a controlled speed. 300 inches per minute
G1 F500 would be faster.
Ect
However if you have your program set up right the 300 means inches per minute if you are using inches. That is a very fast feed rate for most systems..
As you try to go faster you are much more likely to lose steps. Asuming this is a stepper based system.
Again G0 is defined as Rapid Positioning Command ( no cutting) per the
CNC Pro Documention..
Garry
Becouse of problems with the software I couldnt even set the feedrate with G01.
This is fixed and the system is perfectly running again!
My settings are in metric, so 300 millimeter per minute. Not very fast but need this for engraving.
