Originally Posted by oldjohn G'day
I could no find G0 G1 and F codes other than G0 at the start of the program  |
Thats the one
G0 F300
The F300 doesn't do anything.
The G0 says go as fast as it can go.. You should never be able to actually do work with a G0 command it is just for moving to a new location or returning home.
G1 F300 means to move at a controlled speed. 300 inches per minute
G1 F500 would be faster.
Ect
However if you have your program set up right the 300 means inches per minute if you are using inches. That is a very fast feed rate for most systems..
As you try to go faster you are much more likely to lose steps. Asuming this is a stepper based system.
Again G0 is defined as Rapid Positioning Command ( no cutting) per the
CNC Pro Documention..
Garry
