set up you feed rate on the z axis proportional to drill speed if you have it set properly you will not break the bits.start with .oo3 per revolution smaller drill bits have to run fast to keep from breaking. multiply3x cutting speed required 80 is a good speed for HSS in cold rolled steel diviced by the diameter of the bit. |
