Old 08-23-2009, 10:56 PM
damelman damelman is offline
damelman is on a distinguished road
Almost 2 years to the day since last post. Just powered up machine last week
power monitor board still didn't work. (5 vdc leads fell off) Bypassed the board, tied the output directly to the 5 volt power supply. Powered up control
saw checking memory then screen went blank.
Researched this thread, hit exit then main screen came up with drives not on message. Pushed and released e stop button drives moved a split second then faulted with a X-axis lag error. Hit exit to clear fault then paged through the menus to the pal page. On the bottom right parameter changed the gain from the default -2 to 1 then hit enter. Control up and running.
500 oz inch motors,500 line encoders, 7 volts per 1000 rpm tach.
Thanks to all the info provided by the bandit experts, I'm gonna need it
to get my Bandit II with resolvers up and running.
