Originally Posted by RICHARD ZASTROW z28, I've tried to find info on NKN needle bearing dimensions with no luck. Then tried other manufacturers but nothing on 21 x 27 x 15 size.
Can you possibly change to a standard readily available size? Sorry, I can't help as is.
Dick Z |
I found this thread through Google.
Do you have those bearings? 27 bore 21 shaft 15 width
I need that exact size for suspension linkage. I only need 2 bearings but I can oly find a kit that includes everything.
Edit: Ooops, sorry I quoted the wrong post.
