Do you have a switch in line with your motor. I would start by measuring the voltage at the motor (motor off) and shaking the cord. That should give you a good idea if it is a problem with something between the mains plug and the motor. I guess it could also be a loose connection where the mains cord is connected to the motor.
__________________ Jeff Birt |
