Old 08-20-2009, 10:23 AM
nismopu nismopu is offline
nismopu is on a distinguished road
new guy with an accuslide
I just purchased an accuide from a machine wholesaler. Its not the rocksolid version even though I wish it was, lol. It has a fagor8025 controller and it came with a manual but the manual doesn't go very in depth into parameter setting. I don't have the machine home yet but it seems as though the controller thinks its at the x-axis limit all the time. I went into parameters and changed the value in the controller at the guys shop where I was testing it out. I just wanna know what the actual values are supposed to be? After I changed the values I could finally run my program and the machines works awesome! It should be up and running in my garage by next week. Hopefully someone on here will know the answer. Also, is there anything else I should look at servicing or doing to the machine before I start running it? Someone mentioned something about axis drive motors burning up and putting resetable fuses in line? Thanks in advance for any help you guys can provide.
