Real similar. More shaft showing mean more or less oil?
Originally Posted by avtechmachine Is your machine lubepump look like attach picture? sound like very close the same, this lube pump if you need to increase or decrease lube oil, just break loose the set screw on the plunger and remove the snap ring, turn plunger CW or CCW to increase or decrease oil each time it pump
Ahn Vuong |
