I checked all the limit switches and they are good. Emergency stop not activated. All axis are not in limit state. I push the limit override and the light stays on. I tried holding the override button down and that doesn't help. I have to take the plastic cover off of CR1 and push the contacts over for it to engage and then the limit light goes dim and then I can jog the machine. According to the manual when pin 4 on the relay is at ground then the relay is off. Pin 4 is at ground and when I pull the wire off of pin 4 then the relay kicks. 24V supply checks out good. Will I be able to get this BPT usable with 208V on that 230V transformer or will I have to find one? The voltage at the fuse on the z-axis is about 17V when I try to jog it. Also the z has gone from stalling to just giving a whirrrr sound. I also cleaned the quill. |
