Old 08-17-2009, 10:44 PM
tof1 tof1 is offline
tof1 is on a distinguished road
Is something mechanical the only thing that can cause the jagged cuts or can it be something with the programming?
I actually checked the loop corners box but didn't see a change on the cutting path. Do you know if there's a setting in sheetcam that I can modify? I was also wondering if you do this, is it bad to cut over the gap of the cut you just made?
