Old 02-17-2005, 05:10 PM
craig96us's Avatar
craig96us craig96us is offline
craig96us is on a distinguished road
Originally Posted by puller482
Craig here is a link to some files if you scroll down thru them you will find some info on changing those transistors. Be sure to use the heat sink compound when installing the block back on the heat sink.
Good Luck
http://metalworking.com/DropBox/_2000_retired_files/
I was able to locate files that appear to be related to diode replacement here, but I didn't see anything about the transistor replacement... Perhaps you can give me a filename? There are a LOT of files in that folder!
Thanks!
/Craig.
