Need help with machining parameters | | I have to machine a part out of Delrin, Plexi or Lexan. Will use 2mm diameter endmill on a machine with max spindle speed of 7500 RPM and 20 HP motor.
I need an advice on machining parameters:
- should I cut deeper than 1mm in a single pass?
- what would be the highest acceptable federate with cooling on? |
