Does anybody have any experience with the Sherline model 2000? It looks like a decent compromise to at least learn the basics of CNC machining, while still allowing reasonably sized milled metal parts. The big downside I have seen with most of the other setups (Taig, Harbor Freight, etc) is that the Y axis is limited to 4 or 5 inches.
The model 2000 offers 9" in X, and 7" in Y, so that is closer to what I need.
http://www.sherline.com/mills.htm http://www.sherline.com/2000pg.htm
I also looked at the SuperTech MiniRobo router with the RoboZip tool. That offers 12" x by 8" y.
http://www.super-tech.com/root/miniroboiii/
I'm really looking for a system that is bolt together. Not nescessarily plug and play, but at least well documented.
The Sherline is appealing because I can get a CNC ready mill with a work area that I can use.
The Super-Tech is appealing because it is plug and play, out of the box.
Any experience with either that would sway it?
