Old 08-13-2009, 11:29 PM
Geof Geof is online now
Originally Posted by Al_The_Man View Post
..... maybe there is a spindle parameter that can be adjusted to improve it?
There is a Parameter that sets the maximum acceleration load and the machines come out of the factory with it set at 195%. It is possible you could bump it up but then if you were doing a short cycle part you would probably overheat the drive.
