Originally Posted by keebler303 I don't think this is the easiest, lets say you have 6 different drill sizes, you gonna change tools (probably by hand) 6 times or 24? Even if its one drill and one routing bit, its still 4 times as many tool changes. Definitely the best way is to just copy the board layout and paste it again to tile it as many times as you want. It also removes a lot of opportunity for fat fingering your coordinates and making scrap.
Matt |
The drill file is a different file than the mill file. Drill files are easy to edit and combine. If you don't know G-code at all, then you maybe correct, but if you know a little g-code, its more difficult to panelize in Eagle and it be correct than it is to modify G-code and use offsets.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com |
