Actually the easiest is to do the design in eagle and the run pcbgcode to create the necessary gcode. Copy and past the gcode for each additional copy of the pcb you want to make and use the G-code fixture offsets to redine zero or home for each of the subsequent copies. G54-G59.3 http://www.linuxcnc.org/handbook/gcode/g-code.html and http://wiki.linuxcnc.org/cgi-bin/emc...rdinateSystems
You actually don't have to copy and paste if you just want to edite the g-code after each run, or if your using Mach3 selecting the new offsets after each run.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com |
