I have a BP Series 1 CNC with a Limit Override light that will not go out when I push the button. I can manually click the CR1 relay and the light will dim and let me jog the machine. I can then push the limit override again and I hear a relay in the head click. I can jog it in G-code but it will not do anything when it gets to a feed. I have a feeling that there is a combination of relays that may not be working. Any ideas? The ACC board has a spot on it that is a little brown where it may have gotten hot. The z-axis also stalls when jogging.
