Old 08-11-2009, 09:42 AM
Boots Boots is offline
Boots is on a distinguished road
Burrs are a by-product of Machining and therefor very difficult to eliminate. The only machining I have seen that produces little or no burrs is waterjet and EDM. Other than that rubbing 2 pieces of metal together to make one smaller will produce a burr no matter how sharp one of the parts are. I often run lite finishing passes to eliminate burrs and change the finishing tool often. I also use a vibratory deburring machine with the proper stones, being careful not to ruin the finish. You can also use a bead blaster to remove burrs so long as that type of finish is ok at the burr site.
We all live in Tents! Some live in content others live in discontent.
