Originally Posted by MarkT On most turning centers I deal with the incremental commands are (U) for "X", (W) for "Z" and (H) for "C". The primary advantage from my perspective is when generating gode at the machine. It provides you a quick method of moving the machine (example - relieving a tool after a cut) without having to "do the math".
These are also addresses within numerous canned and multiple repetitive cycles within many controls.
Hope this helps.
Mark T. |
Ok....Mark....
So is that so that U & W are used mostly on turning centre... Does they exist on a machining centre...???
Sometimes i feel that that these Address used for axis defination are so confusing....For example, "U axis is a relative movement in a turning centre & the same U axis is a taper cutting axis on WireCut"....These Manufacturer have clubbed address so it hard for anybody to interpret it easily..............Well just wanted to express manufacturer's desire...........
