If you clean out the unused features in the part navigator, it seems to help for a while. Also doing a part cleanup seems to be a work around. i have been fighting this problem in NX5 since we moved from NX4. It seems that when you copy and paste operations in program order view that the errors start occurring. If you delete the last operation you copied, if this is the case, it should let the errors subside. This issue is allegedly resolved in the new maintenance packs for NX5 and 6 but i have yet to see much progress in NX5. Hope this helps a little. If you find a proven fix I would sure like to know about it. |
