Thread: Newbie CNC Newbie Questions
Old 08-10-2009, 01:56 PM
Smokingman Smokingman is offline
Smokingman is on a distinguished road
I am very new to CNC, in fact I just got my first one this week. I spend the past few months doing research and trying to learn everything I could before I purchased.
This is what I ended up getting:
KG3925-G
0.75" top
8" Z-axis
HST 3HP 18,000rpm Spindle
RhinoCAD
RhinoCAM
OK, so maybe it's a little overkill for my first CNC. I couldn't help myself.
After reading everything I could get my hands on and using all the software and going through the tutorials, I thought I knew everything I needed to know to figure out how to use this thing properly. I'm learning quickly that there are a few holes in my knowledge.
Although I've been able to design and cut several small projects successfully, I have a few questions I hope someone can help me with.
Feeds and speeds:
I know, big subject. I come from using power tools by hand in my shop. I can feel how fast I can push a router through a piece of wood and listen to the sound to know if I'm going to fast. It seems this experience doesn't help much using a CNC.
I want to know if I'm doing the math right, and this I understand what everything means.
Using the formula:
Feed Rate(ipm)=RPM * [# of flutes] * [Chip load]
Using a 1/2" 2 flute bit in Mahogany cutting 1/2" per pass at 8,600 RPM with a chip load of 0.018" should equal:
8,600 rpm * 2 flutes * 0.018" = 309.6 ipm
That seems awfully fast. Am I doing this right? Also, is this the "proper" speed, or the max speed?
Drilling:
I need to be able to drill deep (up to 2") holes and various diameters (1/8", 3/32", etc). What is the best way to do this? Do I need special bits? Can I simply mount a drill chuck to my spindle? Is that even possible? Or should I just walk the piece over to the drill press?
Final Note:
The guys at K2 were great. Very helpful, and I got my CNC in about 3 weeks. The initial setup was a breeze. I know some people have complained about getting noisy units, but mine is whisper quiet. The loudest part of it (when not cutting anything) is the cooling fan on top of the spindle.
Thanks in advance to anyone who can help with my questions!
