Originally Posted by woodzy .....The only problem I have had is trying to get the suction to start on a large piece of Corian. I needed to place a board across the piece and then pry it a little against the head to start to compress the o-rings. Once they grab – it not going to move....Jeff |
That is a nice looking job.
To get the initial grab for a large piece of material you could try installing a vacuum reservoir and a ball valve between the reservoir and the table. This way you can pump the reservoir down and when you turn on the vaccuum to the table you get a large suck that helps snap the material down against the O-rings and give the final tight seal.
