Old 02-15-2005, 10:36 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Reread what I wrote. A cutter comped program path is full scale, no offset. If you want to calculate all the offset path, then you don't use radius comp at all.
Using cutter comp means that the cutter will be left (or right) of the program coordinates by the radius of the tool.
Where is your call for the control to retrieve a value from the tool comp register?
