So for the arc that I've programmed, do I need to put both I and J in the line to let the machine know that the X and Y are changing, due to the 1" radius?
Or do I only need the I or J on the line to correspond to one axis?
I'm cutting out an 8"x4" rectangular pocket w/1" radius corner in the center of a hot-rolled steel plate.
Bear with me. I learned programming from a fellow employee who didn't have a good grasp on cutter compensation himself, and I haven't been able to take time to use scrap metal and test programming functions to see how they work. |
