One more update. I found the Haas wireless probe setup doc on the web doc#96-10002 Rev G, and it tells you to activate the probes before calibration. This is done with the following code:
(Tool Probe Activation Code)
M59 P1133
G04 P1.0
M59 P1134
(Spindle Probe Activation Code)
M59 P1134
The instructions tell you to activate each one individually and make sure that when you touch the probes that they beep. Well I activated each one and they DO beep when I deflect them.
This tells me that the probes are sending and receiving signals, and there is no obstructions to block the signals. It would seem to me that everything should be working correctly???? |
