  #12   Ban this user!
Old 08-09-2009, 02:38 AM
SlowRiderr SlowRiderr is offline
SlowRiderr is on a distinguished road
Check to make sure it isn't rusted after you clean it. I used 2000+ grit sandpaper oiled with WD40 and turned the spindle CW at a low speed and cleaned up the internal taper on my machine.
The spindles are the same for TM1 and TM1P. The TM1 has different max rpm and frequency numbers in the parameters.
