Most objects are turned into 3D with the Surfacing commands.
The NURBS surface commands has 2 extrude commands and a command called Linear Sweep. I believe the Linear Sweep is possibly what you are looking for. You can shortcut the entries of the points with this commands by only entering one axis...for example, if you want to sweep a curve(s) from Z0.0 to Z-2.0 then type it in exactly that way...using the Z prefix tells the command manager to assume X and Y are 0.0.
