Old 08-08-2009, 02:35 AM
freedom2000 freedom2000 is offline
freedom2000 is on a distinguished road
Originally Posted by Edwardo View Post
Negative on that.... the torch lowers and touches the metal before firering, it does this to find the top of the metal, height will vary with different thicknesses of metal, then rises to a pre-set peirce height, then fires and blows a hole through the metal, then the torch lowers to the pre-set cutting hieght and continues cutting... this all happens within a very short period of time... with thicker metal you can also set a peirce delay to ensure that the hole is completely blown through the metal before the torch begins to lower to the cutting height to avoid the splash back of molten metal into the torch nozzle. Ideally with my torch and cnc, you never want the torch to touch the metal when it is peircing or cutting, it will ruin the nozzle and possible the the electrode inside... which is the least damage that can occur.... check youtube and seach Dynatorch... there are videos that show the cnc plasma torches working, you will see what i mean...
EDD
OK thanks again. This was the final precision that I wanted to get !
The cheap model that I suggested is ONLY starting the arc when touching the metal. You have then to climb up a bit. But while this happens the torch is on... which can probably ruin the torch during this (short) delay ???
JP
