Originally Posted by Hack I formatted my windows 95 machine today. I am going to use it in dos mode to run Turbocnc for my homemade cnc router. I formatted it so that I could do a fresh install of Win95 as I knew I had lots of garbage on this machine that was know longer needed.
I was able to formate the drive and reboot the system. From dos prompt, I can type in d: and it will give me a d: command prompt like it is recognizing the cd drive. When I type in dir to get a directory of whats on the disk (which is my win95 disk) it says that it cannot read from the drive.
I thought that it was a bad drive and tried a spare that I had setting around and I got the same thing. Is it possible that I have 2 bad cd drives or am I missing something simple?
Dan |
I'm going to guess that the win 95 boot disk creates a RAM disk, which your seeing as D: Your cd probably isn't being seen due to drivers not being loaded.
