Old 08-06-2009, 12:37 PM
Jerry Shorter Jerry Shorter is offline
Jerry Shorter is on a distinguished road
Unhappy Fagor 8025T dripfeed problem
Hello,
I'm having problems figuring out the proceedure to drip feed to my 8025T using the DNC option. I am able to send programs back and forth between my laptop and CNC using various terminal pgms (PCWIN, Hyperterminal, etc.) with no problems. So I'm sure that my cabling and protocal are correct.
I have WinDnc set up at 1200,7,e,2 (same as PCWIN and CNC) However I always get "TRANSMISSION ERROR". when I press send in WinDnc
I'm not sure how to set up the CNC to recieve dripfeed: other than Op Mode 7 -6 (DNC ON) Then what?. Do I start the transmission from Windnc at this point or do I go to Op Mode 0 and start the transmission. (tried both with no luck)
The Auto screen has DNC flashing at the top of the screen and below that is N* If I push start at this point I get "error 014".
Maybe my whole though process is wrong. (wouldn"t be the first time.) any help would be greatly appreciated.
Jerry
