are the tm1p spindles not grease packed , like the tm1. if they are oil feed then air will come out the set srew on the side and out the bottom of the spindle the tm is also famous for sticking tool holders some sound like a shotgun going off coming out of the taper and others sound like a feather droping been running my tm for 6 years. keep the tools and spindle clean and you should be good to go |
