Your IOGear HAS TO have the software installed that maps it as a com port.
I am willing to bet that you have done this already or it probably wouldn't work with the Mazak either.
When setting up WINDNC you will have to check the COM properties in MS Windows to see where the adapter is addressed so that you can pick the correct port in WinDNC.
I also found that Fagor/WinDNC (contrary to the normal "slower always works") needed to run the baud rate really high or it wouldn't COM.
